Closed loop is not forming a "face"
underground_volcano_manunderground_volcano_man Member Posts: 4
https://cad.onshape.com/documents/0b2800c8274d4085010faf25/w/d3390a90e8eef2e20d3bc9a1/e/fb298bbf4e866727d0dc66e0
I don't understand why I can't get a face from this loop even when taking an indirect route with physical part for forming the loop. I quite literally has to be a closed loop so how is it not working.
  • martin_kopplowmartin_kopplow Member Posts: 1,288 PRO
    edited June 2025
    @underground_volcano_man
    There appears to be an error where one line segment end point is skipped in the loop two times on every tooth ground.
    May I ask why you split the loop up into myriads of straight line segments when you could have had it as splines?
    This gave you this mess:
    While you could have had it like this (quick sample):
    With a lot less possibilities for errors or sketcher overload. (Plus it works). Besides that, I'd probably only sketch ONE tooth of each gear and have a circular pattern do the rest of the job.
