Assembly rendering seems broken in my model
joshtargo
Member Posts: 472 EDU
When I shrink the size of my sprocket, Onshape is leaving remnants of faces from the previous size. The halo of sprocket teeth is not geometry, just render artifact
https://cad.onshape.com/documents/e72b6c7b258f55661cf2d0ca/w/64769064665850fe560aa3e3/e/61ab23f8b988f0b82b103dd1
Also when I change hub hole shape.
It does it even after SHIFT F5
