Oval cutout after bending
nagy_laszlo
Member Posts: 6 ✭
in Drawings
Hello!
I received a part to draw.
I have no problem with drawing, but how can I simply put the oval part in the folded part?
I used to use Autodesk Inventor, there was a function where I pressed an unfold option on the finished part, put the oval in it, cut it out, and then refold.
How do I do it here?
See the flat pattern part in the sheet metal tab on the right? you can actually sketch and extrude there as well. probably the easiest way.
sketch1 and sheet metal model 1 are made in 3d space
sketch2 and extrude1 are created in flat pattern tab. See how the extrude dialogue adapts?
Thank you!
I did it!
