Part alignment using width mate
graham_lock
graham_lock Member Posts: 277 PRO
Hi,
I'm using the new width mate to centralise a pully in a holder as below:
After having setup the width mate what is the correct way to then align the pulley holes?
Or should I just use a fasten mate with an offset?
Any help appreciated.
Thank you.
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,930 PRO
    edited July 2025 Answer ✓
    A cylindrical mate should do it (or a slider if you don't want it to spin).
  • MDesign
    In case you wanted to go for efficiency…A single revolute mate would apply well in this situation. no need for both a width and cylindrical mates.
  • eric_pesty
  • graham_lock
    Thanks Eric, the cylindrical mate works well.
  • MDesign
  • graham_lock
    Thank you - yes that also works well.
