New Feature: Tween Curve (WIP)
Derek_Van_Allen_BD
Derek_Van_Allen_BD Member Posts: 1,170 PRO
This is a bit of work in progress at the moment but it's semi functional and I need to work on other tools that this tool is the backbone of. Posting now for public comment. Introducing Tween Curve
Simply select input curve A and input curve B and input a tween value between 0 and 1 and this tool outputs an approximate medial curve AB that is that percentage morphed between the two inputs.
Currently it's limited to single edges for each of the inputs because I'm still working out how to make piecewise segments work for continuous path geometry. This tool by itself is already useful for some workflows but the larger goal is to use this feature as a starting point for other features I've got planned like a frame unrolling script that can unfold frame geometry with a k factor specified by the tween, or other shape deformation scripts that I've got in the works.
