Demonstration: Enhanced Debugger FeatureScript
deDev0
deDev0 Member Posts: 5 ✭
Yes! The debugger can actually be smooth to use. And with this little trick, you can surgically Debug!
Essentially this involves incorporating the → 'arrow' syntax, and a standard use of Lambdas to bypass the ever abundant "context". Some other functions for println, and colored Debug are also included.
https://cad.onshape.com/documents/1b537493cc24dea3fbea7e56/w/22ee6367e145bb6e2d9b5052/e/d18fee2f2b526d12bc7c0f50
Here are the snippets for easy access. Though the actual document is fully commented.
var c is Context = context;
var clrs = [DebugColor.RED, DebugColor.GREEN, DebugColor.BLUE, DebugColor.CYAN, DebugColor.MAGENTA, DebugColor.YELLOW, DebugColor.ORANGE]; // DebugColor.BLACK
var d = s => { c -> debug(s); return s; };
var dc = (s, clr is DebugColor) => { c -> debug(s, clr); return s; };
var p = (arr is array) => println(arr -> foldArray((a, b) => { return a ~ "\n" ~ toString(b); }));
var pl = (s is string) => println("-=-=-=-=-=-=-=-" ~ (s != "" ? " [" ~ s ~ "] -" : "" ) ~ "=-=-=-=-=-=-=-");
  • Konst_Sh
    Nice to meet same arrow syntax abuser as myself 😅
    Using for long time an overload of debug function which takes value as first argument and context as second one and returns value.
    export function debugReturn(value, context is Context)
    debug(context, value);
    return value;
