Auto-number text on the same face of all parts
rashuge
rashuge Member Posts: 11 ✭
I am looking to try and make a FeatureScript that I can select a face, it will then place text with size and font as variables, on the face of every part. I have been trying to utilize Gemini and other AI tools to assist but the translation of how to actually use the code is limited and I am running into errors. What is the best recommended path? This is the code I got.
// FeatureScript 1.0;
import(path : "onshape/std/geometry.fs", version : "1.0");
// Define the user-facing name of the feature
annotation { "Feature Type Name" : "Sequential Part Numbers" }
export const sequentialPartNumbers = featureScript(3) {
// Define the UI parameters for the user
annotation {
"Name" : "Faces to Number",
"Description" : "Select faces in the order you want them numbered (1, 2, 3...).",
"Filter" : "Face",
"MaxNumberOfPicks" : -1 // Allow selecting an unlimited number of faces
definition.faces is array of Query;
annotation { "Name" : "Text Height", "Description" : "The height of the number text." }
definition.textHeight is Length;
annotation { "Name" : "Cut Depth", "Description" : "The total symmetric depth of the cut." }
definition.depth is Length;
annotation { "Name" : "Font Name", "Description" : "The font to use for the numbers (e.g., Roboto, Arial)." }
definition.font is string;
// The main logic of the FeatureScript
precondition
// Ensure the feature is used in a Part Studio
isAtLeast(evaluateQuery(context, qPartStudio), 1);
// The execution block where the geometry is created
execution
// Loop through each face selected by the user
for (var i = 0; i < size(definition.faces); i += 1)
// The part number is the loop index plus one
var partNumber = "" ~ (i + 1);
var faceQuery = definition.faces[i];
// Create a unique ID for this specific operation to avoid conflicts
var id = id + i;
// Get the body (part) that the selected face belongs to
var bodyToCut = evaluateQuery(context, qOwnerBody(faceQuery));
// Find the geometric center of the face to place the text
var planeOnFace = evFaceTangentPlane(context, { "face" : faceQuery, "parameter" : vector(0.5, 0.5) });
// Create a new sketch on the selected face
var newSketch = newSketchOnPlane(context, id + "sketch", { "sketchPlane" : planeOnFace });
// Add the number text to the sketch
opSketchText(context, id + "sketchText", {
"sketch" : newSketch,
"text" : partNumber,
"fontName" : definition.font,
"height" : definition.textHeight,
"transform" : fromPlane(planeOnFace) // Use the face's center and orientation
// Extrude the sketch text as a symmetric cut
opExtrude(context, id + "extrude", {
"entities" : newSketch,
"operationType" : OperationType.REMOVE,
"extrudeType" : ExtrudeType.SYMMETRIC,
"depth" : definition.depth,
"applyTo" : bodyToCut // Ensure the cut only affects the correct part
// Set default values for the parameters to make the feature easier to use
initialParameters
definition.textHeight = 0.25 * inch;
definition.depth = 0.05 * inch;
definition.font = "Roboto";
I know that I am missing something. I am more than willing to dig in and try to figure it out. But, at the very least if someone can point me in the right direction to get started, I would appreciate it.
  • Caden_Armstrong
    Caden_Armstrong Member Posts: 471 PRO
    AI tools are pretty much useless for writing featurescripts. I don't think your script even has a single correct line of code in it.
    Have you considered using an existing feature such as the PP Surface text:
    https://cad.onshape.com/documents/cfec40e2b66bb4ddb2f3414b/w/24132f252a02825eb0606641/e/c8e6602fb08acac97a10a38e
    Adding text to a surface in a feature brings up a bunch of challenges, such as baseline orientation, how to handle non-planar surfaces, etc. Its not an easy first featurescript.
    If you want to learn featurescript, try the course onshape course:
    https://learn.onshape.com/courses/featurescript-fundamentals
