Automatic redlines to compare drawing revisions
trevintrevin Member, pcbaevp Posts: 6 PRO
When you are releasing a new revision of a large drawing package the review process can get difficult and tedious even if only a few things have been updated. If I spent several hours carefully reviewing the initial release of a drawing I should only need to review the things that have been changed when a new release candidate is submitted as far as I can tell there is no way to quickly see what has been changed or updated. I either have to ask the designer and hope he doesn't forget anything (or something changed/updated without his knowledge) or look through everything again as if it was the initial release all over again. Onshape has the functionality to compare different versions for 3D models. I would argue that this functionality is even more critical for drawings. I would guess that is also easier to implement. I am surprised this is not an option.
