Search result names
Justin_Winkelmann
Member Posts: 2 ✭
in General
Why are some search results pulling the property name while others use a generic name even though within the file it is named correctly?
In the example below I have the part number in the part name and I am searching the first part of the number. This should pull up several different files / assemblies.
- All files, assemblies, and parts use the same attributes and filled out similarly
- If two assemblies are within the same file, both will say "Assembly 1" even though both have respective names
- The "correct" search results are my older files, while the new files use the generic name
- Hovering over the search result shows the correct file name (with the generic assembly name) and clicking the link brings me to the correct file and tab
