How to use a set of lines from a derived part to create a new shape?
w_s856w_s856 Member Posts: 57
edited July 24 in Using Onshape
Context: https://cad.onshape.com/documents/efbbafb6b05d800790768197/w/c4dfe0ff6af112e209c97839/e/ef4e701aef64290f85b45bfe?renderMode=0&uiState=6882572da27d1511c889e3bd
I am building a box for an intercom. I would like to use the edge of the intercom (the blue line below) to create a new shape (in the current part studio, the intercom is a derived part), slightly offset on the plane of the top of teh intercom, from the intercom (the red line, it is just a fragment for clarity) that I will later offset and continue with the enclosure.
My problem: I do not know how to do that. I tried to select the edge, and then "offset" but the offset was down the intercom, without the possibility to choose the plan I want to offet on.
What are the appropriate tools to use?
Note: don't pay attention to the cylinder thingie, it is another derived part I will use later and that should be hidden for now)
  • MichaelPascoeMichaelPascoe Member Posts: 2,673 PRO
    There are several ways to offset. A decently robust way to do it is to use Offset surface along the border faces, then use the edge of surface for anything you like. I recommend staying away from the sketch offset tool, sketches can become unstable very quickly.
    Another tool that you will find useful later in the process is Booleansubtract. Use this to subtract your template part from the main shape and you can include offset values within the boolean.
  • jelte_steur_infojelte_steur_info Member Posts: 587 PRO
    another options:
    try selecting the blue edges and use a 'ruled surface' play around with the settings, to create the surface you want. then thicken to make a part from it.
