Repair Faulty Imports
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
Is there any way to edit or repair faulty imports afterwards? It's super annoying to receive a step and then have it permanently displayed in red just because it appears to be faulty, this always extends into the assembly, It's kinda annoying…
Best regards,
Axel Kollmenter
  • S1monS1mon Member Posts: 3,777 PRO
    It depends on the issue. Sometimes I’ve managed to do some manual surfacing work to fix non-manifold issues (very common with electrical connectors) or faces which don’t trim/merge correctly. Then export and reimport.
    It would be great if there were more tools to repair bad imports more automatically, or even mark them as not an issue.
  • EvanReeseEvanReese Member, Mentor Posts: 2,695 PRO
    Not sure if this is the kind of thing you're dealing with, but here's one approach I recorded not too long ago
    The other thing to check if it's a surface, but should be solid is turn on "Highlight Boundary Edges" in the grey cube menu, and manually fix those areas.
