Change Assembly / Part name via REST API
johannes_3000johannes_3000 Member Posts: 9
Is it possible to change the name of an assembly via the /assemblies/d/{did}/w/{wid}/e/{eid}/modify endpoint?
Is there an endpoint like that for parts coming?
thanks!
  • Caden_ArmstrongCaden_Armstrong Member Posts: 401 PRO
    Assembly metadata data (such as name) is updated with this endpoint:
    https://cad.onshape.com/glassworks/explorer/#/Metadata/updateWVEMetadata
    And you can use this reference guide:
    https://onshape-public.github.io/docs/api-adv/metadata/#updating-metadata
  • johannes_3000johannes_3000 Member Posts: 9
    Thanks, that should do it!
