How can I realign an imported part in Assembly?
w_s856w_s856 Member Posts: 57
Context: https://cad.onshape.com/documents/efbbafb6b05d800790768197/w/c4dfe0ff6af112e209c97839/e/273e533df4c86fad6c4f4a07?renderMode=0&uiState=688e729fd5b2bf27821e63cb
I would like, in Assembly, to reorient the "interphone" part so that it lays flat on a plane. Right now it i swerdly inclined and setting the angles to 0 (in the small reference I can use to rotate a part when I click on it) keeps it misaligned like that.
I thought about mating it to a plane, but there are no planes :) and I cannot find where to add one (ChatGPT is seriously hallucinating on that one…)
  • glen_dewsburyglen_dewsbury Member Posts: 1,223 PRO
    The quickest way is to delete the interphone then insert a new one.
    The triads are an indication of degrees of freedom for that part. Once you fix the interphone the degrees of freedom will be gone.
