Picking co-ordinates from sketch to dump to csv file
Stuart_TodStuart_Tod Member Posts: 65 PRO
Has anyone written a way of picking co-ordinates from a sketch that can be written to a .csv file or similar (ideally straight into Excel spreadsheet!)? I find myself needing to extract all the co-ordinate X,Y pairs from points along a curve (preferably with a mouse click) and having them recorded in a useable format for me to analyse in a spreadsheet. I'm presently doing it manually by clicking on each point and copy/paste the x,y from the measure tab at the bottom of the screen, one at a time. I have over 3000 data points to collect….
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,600 PRO
    I've use the "points to table" FS a few times for similar workflows, but only for a small number of items:
    https://cad.onshape.com/documents/81cac0c3f1a3b3ac209c70d6/v/305b9fa86d6700be596736aa/e/5bcdafea538762bf6f6e89bc
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 382 image
    edited August 2025
    I can imagine a lot of ways this might be done, and especially for the hint you gave us "extract all the co-ordinate X,Y pairs from points along a curve"
    I am assuming you want to sample that edge (or curve) and extract those coordinates at the sampled points.
    Here is a simple implementation that works for sketch entities as well as 3D curves. Coordinates returned are x,y,z.
    https://cad.onshape.com/documents/0cffa5477715a66fdbb82f8f/w/f580449b2189f854cea8f3a7/e/1891b92a55e54f21c73c0024
  • Stuart_TodStuart_Tod Member Posts: 65 PRO
    edited August 2025
    @GregBrown Thanks! I'll try it out this morning. Looks very close to what I want.
    @eric_pesty , exactly what I needed! Thanks.
