no good
marco_rapamarco_rapa Member Posts: 2
I do not like this program.
Too much running around the block to get to a drawing surface to draw.
Sketchup is better than this.
  • martin_kopplowmartin_kopplow Member Posts: 1,309 PRO
    Sketchup is for a different purpose. Apples and Pears.
  • MichaelPascoeMichaelPascoe Member Posts: 2,817 PRO
    edited August 2025
    @marco_rapa what is your end goal?
    Onshape is a feature-based parametric solid modeler with constraints, assemblies, and version-controlled cloud collaboration with customizable tools.
    vs
    SketchUp is a surface-based polygonal modeler optimized for direct manipulation of meshes with less emphasis on parametric relationships or manufacturing.
    RENDERCAD
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 842 PRO
    Emphasis on SketchUp's lack of emphasis on manufacturing. I work in an industry where SketchUp is every designer's favorite tool and it's torture because I need to redraw everything they send me to make it manufacturable. It's a cool tool, unless your goal is to make anything.
  • jnewthjnewth Member, OS Professional Posts: 113 PRO
    As CAD programs go, Onshape has a pretty gentle learning curve, but all CAD programs require some training and practice. Here's where to start:
    1. Hit the docs: https://cad.onshape.com/help/Content/EnterpriseHelp/Content/home.htm and please be sure to hit the primer.
      2. Go through some of the learning pathways: https://learn.onshape.com/learn/learning-path/introduction-to-cad I myself and working my way through the advanced surfacing pathway.
