Translating a part leaves sketches, extrusions, etc behind
frank_paynter
Member Posts: 32 ✭
in Drawings
living hinge - Copy | Part Studio 1
I want to translate an almost finished part closer to the reference origin, so I don't have to keep panning and then zooming in to see part details. However, when I select 'Translate by XYZ and select the part, the part itself moves, but all the underlying sketches/extrusions stayed put. How do I get them all to move along with the part? TIA
Frank
I added constraints and dimensions to the sketches and moved the first sketch to the origin instead of using translate. Would this work?
https://cad.onshape.com/documents/a0e756544a703110b5046db3/w/b4c60e6e01edd8c018427ba6/e/372e2d66c62648e0b4d396f9
Twitter: @BryanLAGdesign
It would help you a lot to learn how to fully constrain your sketches. If you clean them up and constrain them and dimension them from the origin you can put the part where it should be.
https://learn.onshape.com/courses/fundamentals-sketching
