Copying a sketch from one plane to another
ProApeProApe Member Posts: 232 ✭✭
Hello,
Is it possible in Onshape to copy the sketch that is on the top plane to the front plane?
Kind regards
ProApe
https://cad.onshape.com/documents/0799320851742429d9ef0dee/w/507447fdfdfae38e1884a6ac/e/40d05b6464df9edec66a3794?renderMode=0&uiState=68ae21655c9dda4aa53c2426
  • glen_dewsburyglen_dewsbury Member Posts: 1,275 PRO
    You can copy the sketch then start a new sketch and paste on another plane. You'll have translate the sketch to finished position.
  • ProApeProApe Member Posts: 232 ✭✭
    Thank you for the quick response! The works indeed easily.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,550 PRO
    If you want the sketch to be identical (and update if you change the original one) you can do a circular pattern of the sketch itself (using "feature" pattern).
