square rod infill when printing
haydn_jenkehaydn_jenke Member Posts: 2
Hi All,
Very new to this but loving it. Have a creality K1 Max and wanting to print a square rod say 200mm long by 30mmx30mm.
What im wanting is the first 30mm on both ends to print solid by the K1 and the middle can be honeycomb.
How do you achieve this?
  • martin_kopplowmartin_kopplow Member Posts: 1,298 PRO
    That is a setting in the slicer. I don't kow what you use, but I'd print it upright and then just set the required numper of solid layers on top and bottom, light infill for the rest.
    Another approach would be to model in different volumes that touch, and when slicing, just assign different infill density.
