Mouse shortcuts
jonas_fodyjonas_fody Member Posts: 2
Hello community,
I have been working with Onshape for some time now, mainly in conjunction with my 3D printer.
In Bambu Studio, you rotate the model with the left mouse button, whereas in Onshape you use the right mouse button. Switching back and forth between the two programs can be quite confusing.
Unfortunately, I haven't found a way to adjust this setting in Bambu Studio. In Onshape, I looked at the preset profiles (SolidWorks, AutoCAD, etc.), but I didn't see a profile with rotation using the left mouse button.
Does anyone know if there is a setting somewhere to adjust this, either in Bambu Studio or in Onshape?
If anyone has any tips, I would be very grateful!
Many thanks in advance 🙏
  • S1monS1mon Member Posts: 3,887 PRO
    If you use a 3DConnexion Spacemouse, you can use the same motions for a lot of programs (including Onshape and Bambu Studio) and not warp your brain.
