Rotating letters in circular path
jim_deuvalljim_deuvall Member Posts: 2
I have this disc with letters A-Z using surface text arranged along a construction circle on a sketch. I would like the letters to be oriented / pointed toward the bottom instead of the center of the disc.
In other words, the A is oriented correctly, but the H is on its side and subsequent letters are upside down.
Is there a command or parameter or procedure to do this?
Also, using tracking and kerning, I can not get the space between the Z and A to be the same distance as between the A and the B. Without the ~, its zero space between the Z and A. I've tried putting a space after the Z (and before the A) but both are ignored ignored. I have to place a ~ to get it to look close to what I want. Any ideas on that would also be appreciated.
  • S1monS1mon Member Posts: 3,855 PRO
    edited September 2025
    Use @jnewth 's Text feature.
    https://cad.onshape.com/documents/4e187c2b2f7f4974f4e2b612/v/4446c75baffebee73f367acc/e/e8c85370413ae1136b63f9df
