Option for Dark Mode to Automatically Follow System Settings
Dark mode in Onshape is excellent, but I typically use it only in the evenings or when macOS automatically switches to dark mode. Currently, enabling dark mode in Onshape applies only to the active tab, requiring manual activation for each new tab, which is inconvenient. A solution would be to add an option for Onshape to automatically follow the system’s dark mode settings. Thanks.
  • S1monS1mon Member Posts: 3,974 PRO
    If you go into "My account"/"Preferences" you can set it to be persistent (as opposed to the toggle in the menu under your user icon). It doesn't follow the system though.
