Using a twisted face to split parts
graham_lock
graham_lock Member Posts: 277 PRO
edited September 2025 in Community Support
Hi,
Below is an image of the trailing edge of an RC plane wing:
The trailing edge is twisted when wing washout is applied which causes problems with what I want to achieve below:
  1. I need to split the ribs at the front face of the trailing edge and then delete the rearmost parts post split.
  2. I'd like to make the trailing edge profile match the rib profiles.
I did ask the AI Advisor this question: how do I split parts using a twisted face
And the answer was: Sorry, Onshape AI Advisor cannot answer this question.
Any help appreciated.
Thank you.
  • eric_pesty
    edited September 2025 Answer ✓
    You should watch this, lots of very relevant and very good advice:
    https://www.youtube.com/watch?v=DVV71gpNSq8&t=2113s
    And there's an update here as well: https://youtu.be/2aNM5dsUnyw?t=1144
    Actually, this is the one I was thinking of as it specifically discusses washout:
    S1mon Member Posts: 4,637 PRO
    @GregBrown has done several in depth videos on modeling RC airplane wings, engines etc. I would recommend watching those if you haven't so far.
    https://www.youtube.com/watch?v=ytZVIfquMF4
  • Matt_Shields
    You definitely don't need a planar face to use Split Part.
  • Matt_Shields
    Split Part doesn't work? Maybe share your doc.
  • MDesign
    I'm no airplane design expert or even an ametuer but wouldn't it be easier to start with the surfacing of your wing and build the parts based on that skin?
  • eric_pesty
  • graham_lock
    Thanks everybody.
    @Matt_Shields , no it doesn't work when the face is not planar.
    @MDesign yes that is an approach I'm looking at.
    The @GregBrown videos are very useful, thank you @eric_pesty and @S1mon.
  • Matt_Shields
  • graham_lock
    Thank you @Matt_Shields, you're absolutely right! Not sure where I was going wrong before!
