Hide or delete an imported image
ProApeProApe Member Posts: 219 ✭✭
Hi,
Is it possible to hide or even delete an imported image when it is needed no more or even bothers you?
Salve
Proape
  • S1monS1mon Member Posts: 3,857 PRO
    Yes.
  • ProApeProApe Member Posts: 219 ✭✭
    How?
  • MDesignMDesign Member Posts: 1,281 PRO
    AI search skills unmatched. Been kinda impressed lately with Grok and answers to onshape questions. just basic questions so far.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,039 PRO
    edited September 2025
    When you import an image into a sketch, ONLY put the image there, nothing else. Ok to put a construction line bounding box around it for dimensional purposes. That's it. No lines that you will actually use for extruding later. Complete the sketch.
    Then create a second sketch. This is the sketch where you will draw your lines to trace and/or eyeball reference the image, that you will later use for extruding/revolving/etc.
    Now, you can hide and unhide the image separately from the later geometry.
