How do I query all edges of a face?
forsaken_candy
Member Posts: 9 EDU
I would like to create a query variable to select all edges that form a particular face of a body. I can select the face manually, but not the edges themselves since they change according to parameters. How do I achieve this? Thanks.
EvanReese
Member, Mentor Posts: 2,764 PRO
"loop/chain connected" should do what you're after @forsaken_candy
forsaken_candy
Member Posts: 9 EDU
Thanks, that does what I need. The naming threw me off at first, but thinking about it, of course all edges have to be part of a loop, whether it's the surface boundary or a hole.
In FeatureScript you would use a qAdjacent, but it looks like that is not an option in the query variable feature.
But with the magic of custom features, you can also make your own query variable features - here is a super basic one that does only this.
https://cad.onshape.com/documents/2d428138fcd3196fe9ad3702/w/669b90d0629267a5caf3d54b/e/515f117273637373707c6a32
Sounds like an opportunity for an improvement request to add qAdjacent to regular query variables.
Along with the all the other unsupported queries.
Theres a lot of really useful queries that non-featurescripters don't know about.
Like qLargest, qWithinRadius, qCoincidesWithPlane, qInFrontofPlane, I could go on…
Y'know I was just saying the other week how I wished someone would pick up the torch of the Query Explorer and implement all the modern queries. Now I think Query Explorer's features should be ported to Query Variable in addition to adding support for all the modern queries.
Derek Van Allen | Engineering Consultant | Meddler"loop/chain connected" should do what you're after @forsaken_candy
