Adding Variables To Variable Studios - Very Inconvenient Behavior of TAB-Key
klaus_krämer
Member Posts: 91 ✭✭✭
When adding new variables to Variable Studios, I and supposedly many others enter the new variable's name and press the TAB-Key. The TAB-Key does not behave like "normal", Why doesn't it move into the next column of the newly created variable? It behaves like pressing the ENTER-Key.
That's an inconvenient thing, as you always have to change to your mouse or use the arrow-keys to define the values of the variable. Pleas make the TAB-Key working as it does in most known Tables!
