create a hole
launay_julienlaunay_julien Member Posts: 2
Hello,
Can't create a hole through the thickness of a sheet metal part!?
I've tried everything. Sketching a circle and then removing material, or using the hole tool from a point sketch. Thanks for your help. There's obviously a bug in OnShape when it comes to sheet metal?
Do you have a solution? Thanks.
Your sincerely.
M. Launay
  • S1monS1mon Member Posts: 3,988 PRO
    In general, holes in sheetmetal works just fine. Not sure why you're having an issue.
    Share a public document, and you're more likely to get a solution.
