Generating sheets from pattern with curved pieces
dook_flydook_fly Member Posts: 5
I was designing a simple boat that could be assembled from sheet cardboard or steel, and was surprised to see the sheet metal tool refused to generate a pattern from it.
It seems to not want to generate any curved surfaces, even though I'm quite sure each face is only curved in one dimension, so it should be achievable with sheets.
Any ideas what I'm doing wrong?
https://cad.onshape.com/documents/8d46e17d372d2f45ccb9bb62/w/6c14b8fba383f37e82e840df/e/370f21949e43f7ff1afad505
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 724 PRO
    The sheet metal tools are wigging out when it tries to apply corner relief geometry to some of these razor thin corners you've drawn in this part studio. You can get it to work if you do more than one sheet metal feature.
  • dook_flydook_fly Member Posts: 5
    I've tried thickening the whole thing, and even thickening out individual faces, but sheets still won't generate on curved faces, even though I've definitely generated sheets from curved shapes before.
    Thanks, I was able to get it work that way, and then also simplified my design in a way that didn't have the issue. I don't really get what went wrong, but I'm at least glad "one face at a time" is an effective workaround.
