Setting multiple view
jack_forgejack_forge Member Posts: 4
I would like to ask, instead of having one view of the object, which I can rotate etc., how to have for example 4 views: one normal and three views: from top, right and front. It should look like dividing screen in four sections. Thank you very much!
  • S1monS1mon Member Posts: 4,062 PRO
    You can vote for that here:
    https://forum.onshape.com/discussion/18308/simultaneous-4-view-display-workspace
  • jack_forgejack_forge Member Posts: 4
    So it is not possible at all?
  • MDesignMDesign Member Posts: 1,333 PRO
    I wouldn't say impossible. Nothing stopping you from opening 4 tabs and arrange them on your screen then set the view orientation in each. but its a bit laggy till os requests the update from each change and screen real estate isn't great since all the tools and menus are on all windows
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 838 PRO
    CADSharp's toolbox has a split screen feature that lets you view the same studio from multiple views but it sadly seems to only allow you to nest one level of split screen and not 4 simultaneous views. Apparently @MichaelPascoe anticipated me trying to nest infinite windows inside of each other and doesn't let the toolbox run this feature many levels deep. It does seem to sync better than multiple browser windows being open at once though.
