Getting name of derive that imported parts
kevin_wormington
Member Posts: 2 PRO
Hi, I'm very new to featurescript and I'm making a simple cutlist table which is working. I'm deriving my parts (for example cabinets) from a configured library part. I would like to be able to get the name of the derive feature that imported the parts so I can prepend it's name to the actual part name on the body.
Any pointers would be appreciated.
FeatureScript 2796;
import(path : "onshape/std/table.fs", version : "2796.0");
import(path : "onshape/std/common.fs", version : "2796.0");
annotation { "Table Type Name" : "Cut List" }
export const cutList = defineTable(function(context is Context, definition is map) returns Table
precondition
var columnDefinitions = [
tableColumnDefinition("name", "Part Name"),
tableColumnDefinition("length", "Length"),
tableColumnDefinition("width", "Width"),
tableColumnDefinition("thickness", "Thickness")
var rows = [];
var allFeatures = evaluateQuery(context, qEverything());
for (var part in evaluateQuery(context, qAllModifiableSolidBodies()))
const partName = getProperty(context, {
"entity" : part,
"propertyType" : PropertyType.NAME
var derivedFeatureName = ""; // Default if no Derive/Import is found
var bbox = evBox3d(context, {
"topology" : part,
"tight" : true
// Dimensions are calculated here (assumed to be L, W, T, but unsorted)
var d1 = bbox.maxCorner[0] - bbox.minCorner[0];
var d2 = bbox.maxCorner[1] - bbox.minCorner[1];
var d3 = bbox.maxCorner[2] - bbox.minCorner[2];
var dimensions = [d1, d2, d3];
// Sort ascending: smallest (Thickness) at index 0, largest (Length) at index 2
var sortedDims = sort(dimensions, function(a, b)
return a - b;
// Assign the sorted values to consistent names
var thickness = sortedDims[0]; // Smallest dimension
var width = sortedDims[1]; // Middle dimension
var length = sortedDims[2]; // Largest dimension
rows = append(rows, tableRow({ "name" : partName, "length" : length,
"width" : width, "thickness" : thickness }));
println(derivedFeatureName ~ " " ~ partName ~ "," ~ roundToPrecision(length / millimeter, 1) ~ " mm,"
~ roundToPrecision(width / millimeter, 1) ~ " mm," ~
roundToPrecision(thickness / millimeter, 1) ~ "mm");
return table("Cut List", columnDefinitions, rows);
