WinCNC CAM Studio Post Processor
Corey
Member Posts: 12 EDU
@DrewB_PTC and @Chris Tilton (Can not find user name) I am part of a FRC team and watch the video shared about CAM Studio. I am having issue with a Post Processor for our machine or Lack of working Post.
First off I don't seem to have access to the CAM STUDIO forum that the video told us to use. I can Read the posts there but it is not in the drop down for what forum to add this New Discussion to.
Our Machine is a Shopsaber Pro404 that is running a WinCNC controller. I have tried a few of the Generic Options and found the 3-Axis Generic Milling - Fanuc to output the NC to an almost usable condition. There are a few commands that are not supported out of the box that I found some work arounds for but there are a few outputs that are on one line but WinCNC requires them to be on new lines.
During my testing I used a simple block with 4 drilled holes
Issue one is the job number that is output at the top of the file
- O0001
WinCNC does not recognize this. I have two solutions (1) Delete this line (2) Add this to a file called CNC.MAC that allows me to map non configured codes to new macros. My entry for this is "O0001=[" this tells the controller to skip this.
The Next set of command are M7,M8,M9 These are a bit more simple and required me to add these to CNC.MAC to run my coolant on/off macros
- M7=[Mist Coolant ON]
- M8=M98 C:\Wincnc\COLLANTON.MAC [Flood Coolant ON]
- M9=M98 C:\Wincnc\COLLANTOFF.MAC [Flood Coolant OFF]
The Fanuc post also added a "G17" that is not recognized so I added that to the Ignore in CNC.MAC "G17=["
Now for the lines I can not automate and require Manual edition or Post Post Processing
The Command to Set the spindle speed and turn on are on one line
- S6000 M3
but they need to be on new lines
- S6000
- M3
There was another one liner that failed simulation on the WinCNC controller
G0 G90 G54 G94 ( 0 )
This did work
- G0 G90
- G54 G94 ( 0 )
So did this
- G0
- G90
- G54
- G94
- ( 0 )
From what I under stand there can only be one "G" command per line
I contacted WinCNC and they sent me a sample file that can be used to create a post processor for these controllers. attached to this post
