I sketch a centerpoint rectangle resizing moves center
frank_paynterfrank_paynter Member Posts: 32
If I sketch a centerpoint rectangle using an established point in my sketch, I noticed that resizing the rectangle on-the-fly (using the semi-gray dimension boxes), the resizing is not done symmetrically, causing the centerpoint of the rectangle to move. How do I stop this from happening?
  • S1monS1mon Member Posts: 3,835 PRO
    Are you sure your center point is constrained to something that won't move? If so, changing the dimensions should always resize symmetrically.
  • martin_kopplowmartin_kopplow Member Posts: 1,141 PRO
    Try making a new sketch on one of the standard planes, use the origin as the center point of the rectangle and see if it still happens. If not, your center point was probably not sufficiently constrained.
