Mating two parts in iPad Pro
Erich_KochErich_Koch Member Posts: 27 ✭✭
Having problems mating two parts. See inserted drawing. Mated the corners of the two parts, then set up MOVE and entered the values for X=0.25, Y=3, Z=0. The parts do not mate. What am I doing wrong, or where is my usage of the mating function incorrect?
Should I used a different mate?
Thanks.
  • colemancoleman OS Professional Posts: 244 ✭✭✭
    @Erich_Koch you are creating a mate connector here....not a mate.  After you create this mate connector, you would need to apply a mate to the created connector and the other part.
    Even easier, you can probably skip creating the new mate connector and go straight to a mate and then move the mate.
    Check out some of the videos on mating.
  • Erich_KochErich_Koch Member Posts: 27 ✭✭
    edited February 2016
    @coleman Thanks. Yesterday I finally figured it out. I'm using iPad Pro, so the UI is different. Then, I figured out that it is actually easier to use the finger than the "pencil". The circle with the cross hairs is bigger with the finger.
    I actually really like the onshape mobile platform for mating.
    A quick tip:
    1) single tap geometry of a part to envoke available mates
    2) tap in space and hold to use the precision selection tool to select the specific mate
