Mass Calculation.
Hello,
I have added to al my parts a material with density.
When I do Display mass in my assembly tab I find an other value as when I make a Flattened BOM in a drawing.
The difference is about 1750 gram, 19602 gram (3D Assy tab) versus 21353 gram.
What causes this difference? See also screenshot file.
Happy to take a look, but we will need a link to your document.
I know the cause…….;-)
In my 3D Assembly was one subassembly hidden.
If you then select by square around the visible parts this sub-Assembly will not participate in the mass calculation.
Problem solved :-)
