Flattened Onshape DXF Export Not Accepted by Adobe Illustrator
Hi there,
Just noticed an issue when I was exporting DXFs from Onshape to Adobe Illustrator and am not sure if it's a bug on Onshape or Illustrator's end.
When flattening a curved face in Onshape and then exporting the flattened face as a DXF from a part studio, the exported DXF when imported into Adobe Illustrator is not accepted. A regular DXF file of a face which is already flat (flatten surface tool was not used) imported into Illustrator works fine.
Thanks!
