Struggling to use Constrained Surface, need tips/tricks/help
skelobones
Member Posts: 25 EDU
Hi, I am using Constrained Surface to model on top of a mesh of a flight stick. I initially selecting the mesh body for the stick as a reference, which didn't load, regardless I did not wish to have the inset where a grip rubber would be. I am using constrained surface for individual parts of the stick, & I cannot understand in which order should I be selecting vertices to form a symmetrical shape. What I have made is symmetrical, ("Constrained Surface 1" a surface wrapped underneath the bulb of the flight stick grip) but it is not in line with what I wish to be making.
I really could use some help in my approach to using Constrained Surface, because akin to Loft it seems to need some sort of guide spline , but I am quite confused.
I will keep working on this problem with other methods & if they work, i will mark this resolved & explain my method.
https://cad.onshape.com/documents/42b1afea419de254d09e019e/w/d614246dbde1a091c6b9117b/e/48fbd375558f1c42396d01f9?renderMode=0&uiState=6948a0f016c2860f30402b9a Document is currently public (22.12.25) for Onshape Support & Link Sharing.
