Home› General
Dynamic Frame / Pipe Profiles 🆓
MichaelPascoeMichaelPascoe Member Posts: 2,744 PRO
Automate your workflows! CADSharp Spin (Onshape Summary Image) - No background.gif CADSharp specializes in custom features, apps, and workflows to speed up your daily routines.
Here is a Dynamic Frame / Pipe Profile that you can copy and use for frame libraries.
  • Stabilizes downstream references even if you change sizes.
  • Dynamically updates profile data for cut list.
  • Choose profile display units.
  • Cutlist+ allows you to add this data to your part names or descriptions.
Would be cool if the default frame library also had something like this @NeilCooke.
On a side note, for anyone needing the frame's to properly show up in the assembly bom, you can use Assembly Imposters (Feature + App).
