how do i centre holes?
orrin_mcintoshorrin_mcintosh Member Posts: 6
  • martin_kopplowmartin_kopplow Member Posts: 1,147 PRO
    Best would be to create the hole on the middle. There should be a Mate Connector at the center. Use that as the input for the hole tool. Else, make a sketch on the face, draw a circle, constrain it to the center of the face, extrude. Or, if the hole is in an imported part, use the move face tool, translate, select the hole center as start point and the face center as the target point.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 729 ✭✭✭
    Most of the time, here's how I do it. Construction line corner to corner. Place point at center of construction line. - Scotty
    Document
