Property Manager (Free App!) 🛠️
MichaelPascoeMichaelPascoe Member Posts: 2,739 PRO
edited January 2 in App Store & Partners Apps
PropertyManager.png Property Manager
A project property manager. Useful for setting bulk properties.
While this is a full tool, it is only a small sample of what  CADSharp Spin (Onshape Summary Image) - No background.gif CADSharp is capable of automating for you.
Property Manager is a sub-app from within the CADSharp Toolbox app.
Once you get the app, don't forget to grant access to the app within your user settings: https://cad.onshape.com/user/applications
  Get it now!
How does it work?
It allows you to manage properties across multiple documents. Data is stored within variable studios for easy access.
  • While inside a document, start the property manager sub-app.
    • If there is no variable studio data, this will create it now.
  • Enter the url's of the documents you want to manage.
  • Within the property manager, you can add existing properties to the list.
  • Once you have added or modified the properties in the list, your ready to click "Set all properties"
How to use Property Manager
Special thanks to CADSharp for sponsoring this app and to @CarlGutierrez for allowing us to re-work the original Property Manager into the toolbox .
If you need custom apps, custom features, or any kind of Onshape training, check out cadsharp.com
  • martin_kopplowmartin_kopplow Member Posts: 1,141 PRO
    That coud be helpful in certain cases and to keep project properties clean.
