Can I save a display state including the section view and the view orientation?
I need to set up display states that include section views and a specific orientation, to use in a publication
Is it possible to save all the view cube option settings in a display state?
  • martin_kopplowmartin_kopplow Member Posts: 1,147 PRO
    You could make a section, then create a 'named view' of it from the view menu found below the cube. AFAIK named views get saved with the display state.
  • Christopher_MoutoulasChristopher_Moutoulas Member Posts: 40 PRO
    excellent, thanks.
    Is there a way to combine a named view with a display state? So I can show the part of the assembly I want, with the cross section I need and at the correct orientation ?
    Yes. Just create the named view in the view state you want to save.
    thanks.
    I choose a display state and then create a named view in that state.
    To show this combination at a later time, I still need a two step operation, 1/ display the desired state and 2/ show the desired view.
    Is there a way to combine the two steps in a single operation that I can link Ito from inside a publication?
