trying to make a ledge to drop lenses into on curved glasses
Hello,
I am trying to make a pair of glasses for a puppet. I have modelled the frame, and used the sweep feature to create the curvature, but now I am stumped trying to make a ledge inside each eye hole for a 3D printed lens (made separately) to be glued into. I want the ledge to come out 1mm from the edge and be recessed 1mm down from the front of the glasses. Imagine if a router had gone around each eye hole.
I am very new to onshape- so I need a step by step explanation please.
Here is a public link to my file- https://cad.onshape.com/documents/b0a5dfd2e217f94c008fa742/w/9f64cda7f21b522b8734cb6a/e/bb39fe1a5d25bd8f1d993574?page=2&email=katherine.hannaford%40det.nsw.edu.au&renderMode=0&uiState=696d9f0d7fc4798666cb28b0
  • CADNurd
    CADNurd Member Posts: 166 ✭✭
    I made a 1mm offset of your sketch, then used that to do an extruded cut up to the face of the frame plus 1mm (offset distance) - https://cad.onshape.com/documents/71ef81a86b19f394a6c561d2/w/7a47520f0ffc03db1e02f22f/e/eaa1963e63d0cdf71fcd7434?renderMode=0&uiState=696e315b465b25b4aa492002
  • katherine_hannaford
    katherine_hannaford Member Posts: 4 ✭
    Thank you CADNurd for taking the time to look at my question, What a great solution. I really appreciate the help. Katherine
  • CADNurd
    @katherine_hannaford - No problem at all. I learned a couple of things myself in the process.
  • nick_papageorge_dayjob
    edited January 20
    The glasses look great for a new user!
    Here is another approach using surfaces. A 3d shape like this is often simpler with surface offsets.
    https://cad.onshape.com/documents/ab88d06e11a1a034078630d4/v/86bff94333908aa02c645ab8/e/4d3226456457ac206bd7a636?showReturnToWorkspaceLink=true
    If you model half the glasses and then mirror at the end, it will save you a lot of work. You have the mirror at the beginning now, and are doing double work for each feature, such as the lens ledge, the hinges, etc.
    You can keep the mirror so you have a sense of what the full glasses look like, then keep rolling back before the mirror to add new features.
    The surfacing technique would also be helpful when you get around to making the lens. I'd probably make the lens much earlier, and use it to make the lip too. When you swept the shape of the frame, if that sweep was a single surface instead of a double sketch cut, it could be the lens surface too. Then you can offset/thicken that root surface separately; Once for the frame (thicker), then again for the lens (thinner)..
    One more since you're new to OS, you can model everything together in the same part studio. The frame, the lens, the temple, etc. (and mirror all at the end).
