putting points on holes
siddik_musaddeksiddik_musaddek Member Posts: 4
Hi if i imported a part that has multiple holes on it
then what is the quickest way i can add points on the centres of those holes all at once so I can use the hole feature to define a certain hole.
Doing a sketch on top of the existing hole takes too long which is why im looking for maybe a featurescript that has this
Thanks,
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,542 PRO
    You should be able to just use mate connectors directly in the hole tool:
    There should be ways to "automate" that using query variables etc but likely not worth the effort unless you have a ton holes to do that way!
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 714 PRO
    If you're looking to do non-hole stuff with imports, my Poly-Mate Connectors feature is designed to give you this kind of non-planar multiselect of mate connectors for other features as well. Combine with Amalgamate to define your own reusable part geometry ecosystem and knock out complex designs without needing to make your own custom features for every little purpose.
