Creating a plane perpendicular between two points
matt_davies955matt_davies955 Member Posts: 5 EDU
I have a drawing exercise I use for teaching with a cuboid. I want the students to be able to create what look like pipes which start on one face and flow to another.
This requires drawing a sketch on the two faces and then creating a spline between the center of these two points to use as the path for the pipe/tube.
From what I understand I need to create a plane that passes through these to points in order to create the spline.
I can't find how to do this. How do I create this plane?
Cheers
  • robert_scott_jr_robert_scott_jr_ Member Posts: 744 ✭✭✭
    Hello Matt. A Three Point Plane would work using a point on each of the existing sketches and a third existing point (perhaps a corner of the cuboid) or one specifically created. - Scotty
    Use a mate connector on the center of one of the edges?
