Right-click on part in Assembly brings no context menu
HARDWOODFP_ENGINEERINGHARDWOODFP_ENGINEERING Member Posts: 23 PRO
Hi all,
When I right-click on a part (either in the Feature tree or directly in the 3D view), nothing happens. No context menu appears. Normally, I would expect options like Hide/Show, Fix, etc., but the menu simply does not show up.
This only happens when right-clicking on a part. If I right-click on the Assembly itself or on a Mate, the context menu appears normally. In Part Studio, everything works as expected as well.
I’ve tested this with different assemblies, different browsers, and restarted my computer, but the issue persists.
I only noticed it today. Previously it worked normally, although I don’t use the Assembly workspace very often, so it’s possible this started a few days ago.
Has anyone else experienced this?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 943 PRO
    I've never seen that one. It definitely seems like a browser glitch, so in those cases I usually recommend:
    • Clear cache
    • Try private/incognito
    • Other browsers (Chrome, Safari, Edge, Firefox, etc.)
    If the issue persists, open a support ticket. Good luck!
  • HARDWOODFP_ENGINEERINGHARDWOODFP_ENGINEERING Member Posts: 23 PRO
    Solved this issue by getting a newer version of my browser. I am using Win7, but found out Chromium still have some builds of the most recent release that supports Windows 7, and that solved my problem.
