how to apply rotate and fixed mate
richard_cox061
Member Posts: 6 ✭
in General
hi how do i apply a rotate mate on something i need to be fixed to another rotate
in my example a gear cluster set where one is 32 teeth and another is 21 i need the 32 to rotate from a 18 tooth input gear so i need the 21-32 cluster to have rotate mates but need them fastened to each other it becomes a problem when applying a gear relation to the 18-32 gear due to the 32 being fastened to the 21 tooth gear hope this makes sense
Rich
Sometimes it is a lot easier to answer such questions when we can see the document. There is a comprehensive chapter on mates in the Learning Section, though, which you might want to work through before.
https://learn.onshape.com/courses/fastened-revolute-slider-mates
hi do i just post the url in here and click share with support ? i have watched videos regarding mates but didnt answer what i needed thanks
Rich
The info in this link should help you post a link to your project that others can work with.
https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first#latest
