Can Sketch Vertices be used as owner Entity for Mates
As per title - I seem to run into a bug where I can use an edge of a sketch as an owner entity, but not vertices/endpoints.
This bug manifests by me initially creating the mate on a sketch endpoint, which then happily assigns the sketch point as the owner entity. When I try and add a rotation through the 'Move' tickbox, the owner entity is lost and am required to use a random edge as an owner entity to attach the mate to the skecth (for downstream sketch driven designs). Vertices no longer seem to be allowed from then onward.
Any thoughts?
  • _anton_anton Member, Onshape Employees Posts: 528 image
    Yeah, we do seem to have an inconsistency - placing a mate connector on a point works fine, but then any further manipulations cause the dialog to error out, and you can't mouse-select a point as an owner. I think the workaround is to input all your moves and rotations first, then place the mate connector.
    I recommend filing a support ticket so that you know when we've fixed it.
