rookie question for best practice
carsten_fischercarsten_fischer Member Posts: 2
Hi guys,
first of all, sorry for my english, I‘m from germany.
I just began learning construction with 3D at all, so I really need basic practices.
My first try, is to create some kind of kitchen cupboard..
For that, I began a sketch on the top layer, to create the bottom of the cupboard, out of a centered rectangle.
I extruded it to 18mm, so I have a simple board.
For one sidepanel, I made a new sketch on the right side of the extruded bottom board, so I could insert a rectangle with the same width, as the depth of the bottom board. Afterwards I extruded it, also to 18mm.
I mirrored this sidepanel to the left side of the bottom so I have two sides and one bottom now.
So far, so good.
Now I want to insert some drilling for wooden dowels on the bottom plates ritght and left side.
In my opinion, I wood insert another sketch on the right side of the botom plate and a sketch on the left side of the botom plate wor some holes.
Is that good way, or is there a better solution for this?
For the sidepanels the same question…
And another question:
Is it sensful to create all parts in one drawing, or would it be a better practice to create the parts in different drawings an stick them together, perhaps in Assembly studio (if this is a stupid idea, I didn‘t work with that at all)
Thanks in advaced
Carsten
  • martin_kopplowmartin_kopplow Member Posts: 1,304 PRO
    edited March 1
    Moin Carsten,
    Du bist da schon auf dem richtigen Weg. Es ist sinnvoll, Teile, die sich später nicht gegeneinander bewegen, erstmal zusammen in einem Part Studio zu bauen. Das wäre z.B. der Korpus deines Schrankes. So kannst du die Maße in Abhängigkeit voneinander festlegen, und einfach editieren. Ich würde aber nur die Teile konstuieren, die ich wirklich brauche.
    Ich würde z.B. vorschlagen, nur eine der beiden Seitenwände zu modellieren, denn die andere kann später einfacher durch ein "Spiegeln" Feature erzeugt werden. Das spart viel Arbeit. Das komplette Produkt sollte man dann in einem Assembly-Studio zusammensetzen, denn dort gibt es Werkzeuge für das Zusammenfügen, für Bewegungen der Teile zueinander und so weiter.
    Was deine Bohrungen angeht: Eine Skizze mit Kreisen, die dann zu Löchern extrudiert werden, ist der naheliegendste, aber auch der mühsamste Weg. Es gibt ein "Bohrung" Feature, das Löcher machen kann, mit Senkungen, Gewinden, Sack- oder Durchgangsloch, etc. Es wirkt auf einen Skizzenpunkt oder einen Mate Connector, der zuvor platziert werden muss. Ich würde damit das jeweils unterste oder das mittlere Loch einer Reihe erzeugen, und dann ein lineares Muster verwenden, das die anderen Löcher generiert. Möglicherweise sind die zwei Reihen der Bohrungen in jeder Seitenplatte sogar symmetrisch, dann kannst Du eine Reihe erzeugen und sie dann spiegeln, um die zweite Reihe zu erhalten. Der Vorteil dieser Methode ist, dass du eigentlich nur ein einziges Loch definieren musst und alle anderen nur Abhängigkeiten davon sind. Per Eingabe neuer Zahlen an einer einzigen Stelle kannst Du dann alles kontrollieren. Ein Bonus ist, dass Löcher, die mit dem Bohrungs-Feature erzeugt werden, später in der abgeleiteten 2D-Zeichnung für den Tischler auch automatisch mit allen Details bemaßt werden können.
    Viel Spaß und Grüße aus Braunschweig.
  • jim_zamecnikjim_zamecnik Member Posts: 32
    Carsten's english is way better than my (nonexistent) German) ;-)
