Exporting letters in SVG (or DXF)
harry_keithharry_keith Member Posts: 12
I've struggle with this before, but this time I am finally asking for help. See project here: https://cad.onshape.com/documents/c210d93a3c6df0ec061a6348/w/088da01c97d6a3d37b881ea0/e/d70a680630c00544fa5b6871
The basic concept is a plate with some letters on it. I need to manufacture it in some fashion. My first thought was Laser. I want the letters to be FULLY etched, not an outline. I export it to SVG, import it into either Inksape or Lightburn, and the letters aren't "closed" (the elements of the edges have gaps somewhere). I also tried with DXF. As a test, I also imported it into Carbide Create, where it complained of un-closed vectors. I could tell it to merge vectors, and then it was happy. As a workaround on this project, I sent it to Cricut to cut out of vinyl (it actually was a better solution to this project), but it cut every single tiny vector as a separate line, taking almost an hour to cut this little file.
What is going on? Why aren't letters exported in SVG or DXF closed vectors? How can I encourage them to be closed? This has to be a common workflow, so I'm certain this is a "me" problem.
Thanks for any help!
Harry
  • harry_keithharry_keith Member Posts: 12
    Well, I've found one solution. If I export to svg from a sketch, the vectors are closed. I was exporting from the drawing, because it has the entire project (base plate and letters). I generally prefer to have all the lettering on a separate sketch.
    So, the question should be rephrased: Is it possible to export a drawing to svg or dxf and have closed vectors, or do I have to put all my work on one sketch and export from a sketch?
