Onshape Glassworks API
Hello,
My name is Gage I am looking for help with a project I am working on. I am trying to essantially search my assembly for all sheet metal parts, check those sheet metal parts size and then export those sheet metal parts as DXFs. The problem I am running into is that I can do that in a part studio but once I try to do that in an assembly it seems to fall apart. I have been able to do all of this into the part studio "following the elements down" but my part studio and my assembly have different configurations and I need the one from the assembly. My work around that I have been trying to use is to pull the assembly configuration with a GET/element/d/{did}/{wvm}/{wvmid}/e/{eid}/configuration. and then pass it to the part studio using a POST, then pull all info needed once the part studio configuration matches the assembly configuration. The problem is that when i run the GET request labeled above the JSON shows me the mins/maxs & defaults of all of my configurations but the place where it is supposed to say the current configuration it says "currentConfiguration" :[]; seemingly empty. Would love some help with this or pointers of how to get this to work. Also good to know that I have to work completely in bash as far as putting together code goes due to limitations of the servers that the company I work for uses.
I was happy someone asked the same question I have. Then sad because no answers.
