Lost my progress.
fropfrop Member Posts: 9
So.. I had enough of my part outlined in a 2d sketch to have a grey line shade everything in. Later I went to add a midpoint of what would be a circle and next thing i know I am back to what things looked like last time I started using the software (which was in the morning. I used it in the morning then stopped and started my task at night again). So... has anyone else had this problem? I have a screen shot of my work before this happened then after. I thought onshape kept a record of everything you did on a project so you could undo anything. The undo and redo buttons aren't available =/
    Undo/redo is only available for current session (Onshape timeouts in 20 minutes if not in use).
    History is recorded though and you can go back between accepted edits.
    //rami
  • fropfrop Member Posts: 9
    One of the mods I think helped me out. Seems like I was doing a sketch and somehow hit cancel so it lost all what I was doing. Can't recover a canceled sketch =/
    @frop ,Currently user cannot recover canceled sketch entity in Onshape. You can raise improvement request for this. In near future we hope that this facility will be provided by Onshape.
    @frop  That is correct.  If you hit cancel and have not committed that active sketch, you cannot undo this.  We are aware of the issue and are working on a solution so that is captured in the history.
