If you would like to contact our Community Manager personally, feel free to  send a private message or an email.
Sketch constraints to faces!
caradon
                    OS Professional, Mentor Posts: 300 PRO
                    Last Onshape update introduced sketch constraints to planes and faces.
Just wanted to say that constraining to faces is SO powerful! Much more robust than referencing edges (or worse: rounded edges). I don't think SolidWorks does this today...
Why I like constraining to faces:
Kudos to the Onshape team!
What do you think?
Dries
- No regeneration errors with added/deleted fillets compared to constraining to edges.
 - More intuitive than constraining to reference planes
 - Very quick. Select point or line, select face, press 'i'... BAM! Done.
What do you think?
Dries
2
It is still confined to planar faces, but that's a great start. It works for planar faces which are not orthogonal to the sketch plane, that's the game changer. Mainly but not only because faces are more durable than edges during model edits, as Dries points out.
Once it works for spline-based faces, it will be a major leap for tricky curvy stuff.
Thanks
Check out this public document:
https://cad.onshape.com/documents/2b0f0cc7d6344ada9a851e36/w/ee0f80e95d8540ce87cae662/e/e7d479af3e2846068732af57
Try and delete 'Fillet - TOP' in both Part Studios.
One will generate errors in the circular hole sketch, while the other will resolve perfectly.
Dries
